hi does any 1 know of a program that i can look and change my phone book on my computer the the tdk bluetooth program that came with data cable does not support the 6600 and the pc suit does not have the function to look at the fone book...any help would be good ...thanks
phone book
Handset Manager used to let you do this - but I dont know if they have relesed the 6600 version yet -
have a look on ..
just looked no they dont do it for the 6600 thanks anyway
Oxygen Phone Manager maybe, doesn't that work with 6600 still? Same as 76/3650 in contacts wise.
Try searching for it, it's quite a good program from what I've read.
Ian
Originally posted by grant15271Microsoft Outlook is one possibility (sync with PC Suite to the phone).
Another option: The "Remote S60" application from Mobileways.
