Undeletable messages
7 replies · 2,722 views · Started 19 December 2003
I can't delete some messages on the phone. My settings is on the MMC. I was able to delete some messages but there are these stubborn messages in Inbox, and Draft folders. How do I delete them using the file explorer?
By the way, has this happened to you..."Failed to write on disk" when sending a message?
THanks.
kobe
download : seleQ
browse in to : folder named "system"
then : "mail"
& search in the subfolder for the undeletable messages .. & delete them
if that doesn't help .. contact me ..
sorry but it doesn�t work, the programm always hangs
so i put the MMC in my Digicam und deleted the Files there
but thank you for your help
I have the same phone problem. I don't have SeleQ but have FExplorer installed. Can anyone tell me how to locate & delete the stubborn file using the FExplorer? Thanks in advance.
Can you please tell me how to identify and locate the files I want to delete?
"Cannot Complete Write to Disk" thats what my cell told me 5 minutes ago when i tried to send an sms 😞 was the first time.
any ideas?
later
it�s no so easy to identify the files, i deleted every file because i had no necessary messages
