I have just got a P900 and am giving Tracker a try. A have a couple of questions though :-
1. If I keep the flip on the phone can Tracker change the screen layout while flip is closed?
2. If I power on the unit Tracker seems to take a long time to load?
3. When going from flip closed to flip open the default SE screen pops up before flipping to Tracker?
I can only assume that Tracker is best when the flip has been removed?
Originally posted by uxbod
Hi,I have just got a P900 and am giving Tracker a try. A have a couple of questions though :-
1: No tracker only effects the layout in flip open mode.
2: This is because when you have previously opened tracker and close the flip the program is still running in the background, after you turn your phone off/on it has to start the program again.
3: This is because it is default for the phone to go to the regular menu, then tracker overrides that (Providing you have set it to do so) so then tracker starts...it is only a short time though.
Fip removed/Flip on, doesn't make so much difference because even when you enable virtual flip then tracker still disappears...although you can enable screen lock in flip removed state with virtual flip off to have tracker present and running all the time.
Just installed Tracker on my P900 and for some strange reason, I am not able to get the Jog Dial down action to work. Up and scolls work fine, but not down.
Have given up and gone back to HandyDay 2004. The only thing I liked about Tracker was the ability to cose applications, which I don't think HD2004 does very well in some cases (e.g. closing of Messages app)
check if u've installed the latest version of Tracker (3.2) and that u've updated your Firmware.. if done, I suggest uninstalling HandyDay and Tracker, then reinstalling it again, as I recall some people faced problems when installing both!😊
