Steve Litchfield explains why SMan should be installed on your P800 or P900 and how it might just save the day... Read on!
Review of SMan for UIQ
thanks for the review . I have now got sman , just wondering how do you remove the sman icon as i note you do not have it in your review. This would be really appreciated.I am a newbie but trying to learn!
If you mean "How do I get rid of SMan again?", just Quit it from the main SMan 'Fn' menu and then Uninstall it as any other utility.
Steve
thanks for the reply ,but i meant the picture icon only, the application is great -only I dont want THAT icon .Any help thanks.
Do you mean the SMan icon or the icon of each application in the main shell?
If you meant the SMan icon, well you can't change it as both Droll and I have decided not to change the icon (not yet anyway).
As for the application icons, that too can't be removed as we found it does not eat addition memory nor slow down SMan.
yes, I meant the Sman icon I appreciate female phone addicts are in the minority but perhaps something less obviously male orientated would be appreciated. Thanks.
Ah I see what you mean now!
I never realised what that icon was but with your hint its suddenly come sharply into focus 😊
