I've never hidden the fact that I love MyList Pro by Ximplify, and now it is even better.... and boy is it better! Just check out this list of improvements that make it well worth the investment......
[list]
Save List as HTML (Dynamic HTML, without Memo)
Generate web pages (Two frame with memo view)
Memo now included in the Save List as CSV & Text File
Save list as formatted EPOC Word (with memo)
Memo View :- EPOC Word Import/Export, Plain Text type file import/export, Export as HTML Page (CSS Support), shirtcut to import current date and time string.
Preferences: Every list has its own UI settings
Send list via Infrared
Unregistered user is allow to use myList as a List Viewer with ability to open & save the file attachment
[/list:u]
So, it looks like Ximplify has looked at my wish-list of extra features and said "that list is too small!". The HTML functionality is outstanding and offers a level of Web site manageability that some desktop application could do with noticing.
For an example of the practial application of this now extremely powerful piece of software (only with IE at the moment), check this and this for an example of what you can now achieve (If the links don't work, hang five, I'm about to go to work for a late shift and I just had to get this posted - and I hope nobody will be offended by the religious nature of these demonstrations pages, but it does show how powerful the software is and it's all I have that I can share publicly at the moment. Needless to say, if this was available when I was running Mobile Musings, things could have been different there)!
It can be purchased from here for only $30 * (affiliate link).
Note
If you're upgrading from a previous version, leave some time for your existing records to be converted the first time you open them. After this takes place, they will open as normal.
* For a limited time only, the price is $21! So get it quick!
