error going in to general under phone setting
6 replies · 4,276 views · Started 19 December 2003
Hi i got these problem going to general under Phone setting.
when ever i open general a window pop up is stated (App. closed gs CONE 14) Another problem i face is I was using Total ir remote at that moment i'm doing some selection of TV model but i cant key in any alphabet that mean no letter only number then from there i go to phone setting then i realise i cant go in General.
I'm Using 7650
Can someone help???
rolandy wrote:Hi i got these problem going to general under Phone setting.
I'm Using 7650
Can someone help???
hello dear
i have the same problem
and i wanna to know the answer
pls
replay to me on [email][email protected][/email]
Did you install wildskinz and unistall it without deactivating it?If so,install it again,activate it,reboot,deactivate it,reboot and uninstall it.
GhostDog wrote:Did you install wildskinz and unistall it without deactivating it?If so,install it again,activate it,reboot,deactivate it,reboot and uninstall it.
dude THANKS SOOOOOOOO MUCH!! i didnt know what the problem was until you, ur a life saver man!
M8 Cheers!!! I Had The Same Problem As These 2. I Went Onto Google And Find Ur Site And Ur Solution Worked. Cheers!!!!!!! Ur A Star!! Wildskinz Sucks C***
FINALLY - Given me the answer to get my phone working again - Same deal: unable to go into General Phone Settings, and unable to write text - Yer a lifesaver
3250 gives an error when m typing msgs "app closed", i thknk the problem with phone RAM(memory), how to keep empty?
plz help me..
Thank you
Pravin
