P900 Welcome screens
4 replies · 2,447 views · Started 19 December 2003
I have a P900 from O2, without a sim card.
I am using T-mobile and Orange Sims and have managed to remove nearly all the O2 logos.
How can i remove the O2 welcome and goodbye logos, and replace them with the original SE logos.
I think the startup/shutdown MP4's are stored on the ROM so they can't be changed (Unlike the P800).
Although if you can get the phone flashed or do a home update (With non O2 firmware) this should remove the O2 branding.
Not sure about the home updates on O2, but Orange doesn't work 😞
Would this work...?
I have entered my CDA number at SE update service, which states that firmware R1A05 is current. However i am aware of newer firmwares.
If i change the last number on my CDA to 3, this indicates a Version R1C01 is the latest version. Does anyone know what network firmware this is.
Also could someone with a UNbranded P900 tell me what the last number on there CDA referes to there original SE logos.
Would it then be possible to then use this last CDA number and perform a SE update with the unbranded Firmware. Which i hope will remove the O2 welcome screens.
Well - if U use qfileman, you can access the startup screens in sysdata - its a shame though the p900 has them listed as read-only and it cannot change them.
Scott
