Oh, It's really cool! FC(Nes) emulator for symbian.
http://www.yewsoft.com
This company developed a FC(Nes) emulator for S60, and it is really cool , the speed and the graphic are perfect.Download page is http://www.yewsoft.com/yewnes/download.php
And it is can run on 6600 device. Woo, it's cool.
Damn I was just about to post this!! Theyve done a pretty good job too but it's a shame there's no sound... Oh well, GoBoy had no sound in the early versions either... 😊
Also a shame the trial time is SOOOO short.... 😞
Hey!
Just wondering what exactly is a FC(Nes) emulator? As I understand it helps me with playing nintendo games on my 6600.
Is there a freeware version of the one available at http://www.yewsoft.com/yewnes/download.php
Where can I get the 8-bit versions of my fav nintendo games - super mario, contra, etc?
Cheers!
Unfortunately it will suffer from the same problem as GoBoy - namely that the joystick included in the 6600 device is only working 4-way. So you can't play games which require diagonal movement - like 90% of the games out there.
In GoBoy you can configure it to use the phone buttons instead of the joystick - but then it's very awkward to use, plus those buttons are absolutely not designed for gaming, so it's not comfortable, and I'm sure they get damaged quite quickly.
anywhere specific i cud go to on the web hunting for 8-bit versions of super mario, contra?
some good roms:
gunsmoke ninja trutles 1.2.3.4 super mario 1.2.3 castlevania 1,2,3,4,5 megaman 1 to 6 and blaster master fester`s quest and alot more because there is alot coool nintendo games and not forget power blade 1-2
