Is this possible?
I've had the 12planet messenger client working perfectly, but jmsn just gives an error, doesn't even ask me what connection i want to use (like other net apps that wont use the pc's connection)
While were at it, Where can i download the latest version of jmsn, i think i have an old version, and it took ages to find too, eventually got it off some strange german fella's ftp site.
Also, there was one other question i had, on an unrelated matter.
How do you make the phone default to give you an sms message report? I know how to set it each time, but i'd like to have it on all the time without having to mess around each time.
Is it possible?
jMSN uses phone's connections only. it's not possible to connect through BT connection. And yes it works perfectly with 12Planet.
About report thing, you can't do that! It is starting to piss me off already. 😞
I believe there r lots of new products u can use to connect to MSN, they were recently released, and u can find them in Handango ..
give them a try let us know which is best😊
Well, if i have to pay for one, then i might aswell use the 12planet one as it works perfectly.
There are 2 free ones on there, i left my docking station at home today, so i'll give them a try later on tonight.
Ideally i dont want to pay for a free service though, which is why i wanted to use jmsn.
I never seem to be able to connect to 12 planet IM+ anymore, have updated the software, but just keeps tying to login for ages and never does, go online with my PC and it connects straight up, any ideas??
Tried agile messenger and connected straight away but that has bugs on p900, plus I have paid for the other one so would like to be able to use it.
I also bought 12 Planet IM but could not get it to connect. I gave up and used Agile.
It worked perfectly first time with MSN and AIM. and it's free - so why not change. It will not cost you any more.
