im using a 128 Mb MMC but the problem i face everytime i send a rather big file 2 my phone like a game or so its saved in my inbox and when the saving to installer banner appears it goes on like that for a minute then says that theres no enuf phone memory...any1 has any suggestions or solutions about my problem?! THANX! 😊
phone memory not helping at all!!
Store your Inbox on the MMC or use Pc File Manager to send files directly to the MMC.
I have the eFile Manager does that help? where can i find the messages in my inbox and how do i know which folders are of the memory card's? Can u set ur inbox so that all ur messages r saved on the memory card directly? Thanx 😊
hi Ph0BiA , go to your messaging folder then press options then settings , scroll down to "other " and select it , now scroll down to " memory in use " and click on it and select " memory card " and all your problems should be over .
hope this helps
gadget
