Dear developer,
I wish to develop an application in OPL for Nokia 9210. That application should be display some component (such as Label of menu bar in my language "Khmer"😉. I have read some document related to the font, they said that we can use other font instead of the default font by using 'gLoadFont' and 'gUnLoadFont'. I am try to do that too but still getting the default font displayed.
I have used some tool that convert from TTF font to GDR file format and I place that file to the folder in which Font are stored. Then I write some OPL code to display that font but I got nothing beside the default font. I mean nothing change for the new font.
The code are :
PROC Test:
LOCAL fontid%
fontid% = gLoadFont("Z:\System\Fonts\lmns1.gdr"😉
PRINT "salaron"
gUnLoadFont(fontid%)
GET
ENDP
I have use this font as a TTF source file(lmns1.ttf). It can be download at http://www.khmer.p2pmessage.com/lmns1.ttf .
How can I do to display my font in Nokia 9210 by using OPL language?. Nowaday I just try it in Emulator Nokia 9210.
Best regards,
Which TTF-GDR conversion tool are you using? Take note that older tools, i.e. Symbian OS v5.0 and earlier, might have problems with Unicode fonts. You could check the output format in a hexeditor.
I'm not sure for the version of this conversion tool. I have use may be an old version of converting tool. I downloaded at http://www.geocities.com/zavorine/epoc/fontutils.htm
(option "ZIP File"😉. I have even try the sample demonstrated font in this package but still not successed.
Could you please give me an advice to archive this goal?
Best regards,
Veasna
You need to set the font after loading it. Now, you only load the font. To set it as the active font, use the FONT command (for text output with PRINT) or gFONT (for graphics output, eg gPRINT).
HTH
Best regards
Arjen
Arjen Broeze wrote:You need to set the font after loading it. Now, you only load the font. To set it as the active font, use the FONT command (for text output with PRINT) or gFONT (for graphics output, eg gPRINT).
Yes! And this brings up another question; you also need to make sure you have UIDs defined, because FONT and gFONT works with font UIDs, not names.
These UIDs should be unique, so you should apply for them from Symbian Dev Net. If they are conflicting with built-in UIDs or other fonts you have loaded, it won't work.
If you check further throughout Alex Zavorine's pages, you will notice that he has assigned such UIDs to his own font creations: ArialNarrow, Math, Comic, Dingbats etc.
Furthermore, font UIDs are long integers (&😉 not short integers (%) as in your loading sequence above.
cheers
Martin
