i just got bluetooth and want to connect my computer to the internet via my phone - what software is there out there 2 do this?
thanks kris
thanks kris
ok i figured out how 2 do it by dialup - but i want 2 do it by gprs - as i get it 4 free 😊 - ne ideas??
you really should search first before asking basic questions 😊
Basically you create a new dialup on your PC using 'bluetooth modem' as the device and use a dummy number instead of the phone number which will trigger GPRS on the phone instead of dialing anything - not sure what the dummy number is off the top of my head, as I say, do a search 😊
Something like #99*
Best
Will
i have searched!
and i can't find nething -
i spent another 3 hours searching for the "dummy number" last night and achieved nothing .. 😞
i called this guy from nokia a few hrs ago and he said that it can't be done - but i no it must be possible - so plz if u no how - could u tell me?
Thanks in advance - Kris
That is not a dummy number its a number that selects the appropriate access point.
Search google for Nokia bluetooth internet sharing.
The number is *99# Enjoy, no login and password needed! at least for me! 😉
The password should be the same as for the GPRS access point.Try numbers like *99***1#, *99***2#, *99***3# if you have more then one access point.*99***1# coresponds to the first access point etc etc.
Try this article over at En-Gaged.co.uk.
