FastSoft releases FastConverter 2.0 for UIQ
0 replies · 1,824 views · Started 23 December 2003
FastConverter 2.0 is the ultimate conversion tool for unit conversion. It has 14 built-in types from Currency, Time or Distance units to Computer units. It provides more that 260 available units including more than 160 world currencies. You can add new types and units needed for your custom conversions.
Features:
  • Simple and Fast conversion user interface.
  • 14 builted-In unit types (Monetary, Speed, Weight and Mass, Temperature, Distance, Time, Volume, Computer, Angles, Area, Power, Energy, Force and Pressure).
  • More than 260 built-in units.
  • Automatically save last conversion units that are restored next time you open FastConverter.
  • Possibility of defining new types - > Custom types.
  • Possibility of adding new units for custom and/or buit-in types with custom description text -> Custom Units.
  • Possibility of edition of Custom units.
  • Improved Delete Custom (you can delete custom units defined in built-in types).
  • Error prevention mechanism in important actions like deleting, save, etc.
  • Clothing conversions.
  • Simple Calculator that enables calculation on "From" text field.
  • Area calculator.
  • On-line currencies update.
  • Possibility of defining the currencies that are showed in drop-down currencies list.
  • Value log for big results in exponencial form.
  • Shows the rate that is used for conversion.
  • Basic operations Help menu.
FastConverter 2.0 is distributed under two versions: Basic (free but with limited resources) and Plus (commercial with access to all features). FastConverter is available to purchase at Handango on-line store.
