Hi Guys,
Been round and round trying to use my 6600 as a modem, as I successfully have with my old 7650.
-Using Win2k btw.
- All my bluetooth stuff to the phone works.
ie: No probs connecting via PcSuite and transferring files etc..(Although was a bitch to get working initially, has a conflict with 7650(
- Eventually removed any software related to 7650 altogether to clean up.
- O.k. So I installed the Nokia Modem Options from Disk. Unlike the documentation suggests
I didn't get a prompt asking how i wanted to connect(bluetooth) It just installs then I reboot, then a bit more installation.
- When I run Modem options from control panel, there was no Modem listed.
- It does mention this could happen in docs and suggests adding the modem manually. Which I have done using ->controlPanels->Modem&Networking
- Modem get added(I choose 6600 from list)
- Modem then appears in Nokia Modem Options.
- Just can't get dial up Networking connections working,
Starts dialling then complains that it can't initialize modem.
I have tried every combination of installing - reinstalling. Checking com ports(all fine btw), Suspect need supported ".inf" from nokia to give when using windows modem add but can't find one anywhere)
Any clues anyone.... ?? Help!!
