Hi Guys, I need help on files with the extension .jar.zip
Must I find install a zip program into my phone to unzip those files with (.jar.zip)?
If this is the case where can I find the Zip Programs?
HELP!!!(.jar.zip)
you can try one of two things.
1 is to use winzip on it, to extract it. however i think it is unlikely anyone would zip a .jar file as they are pretty small for the most part.
try renaming the extension to just .jar and see if that works, i get the feeling that some wires got crossed and a .zip extension was added on the end by mistake..
I remember reading a while ago on AAS a post by RayGun saying that the Jar files can be treated like Zip files - so simply get rid of the .zip part of the name and upload to the phone.
I try to unzip the files using winzip and there all several files with the .class extension and many other .png files in it.
Pls advise wat must I do about it.
Don't unzip,like j2k and Kyuro said,lose the .zip extension by renaming it to .jar and send it to your phone.
