I've added an extra part to my mobilephone website to allow people to download free themes aswell as posting their own themes to be downloaded. There is no point spending all those hours creating themes if you can't share them.
Check it out:
http://www.colourmobiles.co.uk/tpls/colourmobiles/themes.html
P.s: I can convert to .sis and provide screenshots for all themes.
Originally posted by TopB
I've added an extra part to my mobilephone website to allow people to download free themes aswell as posting their own themes to be downloaded. There is no point spending all those hours creating themes if you can't share them.Check it out:
Hi... Can U teach me how to made ScreenShots for my themes.
Thank You.😉
Thank You.😉
Go here mate, http://users.skynet.be/domi/fexplorer.htm
It's a great free file explorer that allows you to take screen shots.
SeleQ and other apps all can take screenshots also. I may be wrond but I'm sure the app 'Screenshot' is a freeware app, but I'm not sure.
Ian
Thanks Coolice.
Actually I have both programs, but I don't know how to do it.
Could you kindly step by step teach me.😕
I follow the instruction inside the program, for example it's said press "ABC" key + Joystick to Capture(ScreenShots). When I did it nothing happen. Please helppp..... 😕 😕
Thank You so much.
Thanks Coolice.Actually I have both programs, but I don't know how to do it.
Thank You so much.
Just Screentaker by SymbianWare and instead of pressing 'ABS+Menu Key' or 'ABC+*' like it says in the instruction, PRESS the PENCIL KEY then the * KEY then a textbox will popup where u can enter the filename of the image to be saved in the Images folder...
Peace out!
