tomtom
12 replies · 4,396 views · Started 25 December 2003
Does any one know if tomtom uses NMEA?
Besides the obvious place where can I find maps for tomtom?
what means NMEA?
i have some maps, but they dont work to 6600,
i need your help to tell me if they work to you.
thanks in advance
I could load them on to my phone but cannot use GPS coz I wont buy the GPS antenna until I know if tomtom uses NMEA, coz the one I want to buy requires the software to use NMEA.
I'm looking to buy th Holux GR-230.
you can ask tomtom about gps support,
where did u find this gps module?
can u provide a link?
____________
macedonia is greek over thousants of years
jojo, here is the link for the gps unit.
HOLUX GR-230
thanks MrDust, I will look for it,
i have seen also some other gps modules,
if you interested, i will find them again.
do u know if there is a greek map for tomtom citymaps?
as i have seen, tomtom doesnt support greek cities,
but the olympic games will be in athens, so its a "must have"
thing !!!!
if you want to see a city called e.g.:
"roma" you need:
1. citymaps application
2. roma map (add on) file
i hope i helped
what means NMEA?
From http://vancouver-webpages.com/peter/nmeafaq.txt :
"NMEA standard defines an electrical interface and data protocol for communications between marine instrumentation."
In many cases it defines how a non-GPS device (computer, PDA, phone, for example) connects to a GPS device.
well, apparently tomtom uses NMEA. ooohhhhhhhh, now I'm really considering getting the Holux. Just need to find full UK road map and if possible a Hong Kong map.
citymaps dont work with countries 😎
they are city-maps! there is kind of software for
communicators (tomtom route planner)
and i think that there are also some other companies
except tomtom for what u need
