I want to learn how can I easily restart Nokia 6600 without turning off , later turn it on and enter pin code! What easy method do you know?
How can I easy restart Nokia 6600!
I use the app called FExplorer, it has a feature of restarting to phone. It nicely starts upp again without entering the pin-code.
You find FExplorer here:
http://users.skynet.be/domi/fexplorer.htm
//highscore
Thank you for your reply! I am using FExplorer V1.05 But I can't find any menu icon or any place for restarting my phone in this application! How do you restart your phone by using FExplorer!
Why don't you try downloading the latest version -1.10.You can restart the phone by selecting -Phone-Restart from FExplorer's Options menu.
SeleQ has also the function to restart your phone
Cheers
FExplorer is free 😉
and also this:
if u send a mail 2 ximplify.com and ask about selecQ and 6600,
they answer that SelecQ is NOT compatible with the 6600.
(even it will run on the device.)
if u install it, any damage are on your own risk.
(i think, it is the autostart feature what could damage the 6600.)
I have install the Progy 2 weeks, nothing bad happens.
after i see this warning from the company self, i remove it.
Why should ximplify send out this warning, if there would be no reason?
Only too loose money with all the new 6600 users?
I think, there is a real reason,
so i trust Ximplify and wait until this good file Man. is realy compatible with the 6600.
and hey:
FExplorer is even my favourite File-man.
Regards and respect too Domi:
he made 4 all of us a real good File-explorer as Freeware.
The Progy is small, stabil and got all the important features like:
search,restart, add 2 Opp-logo, Network infos
and of course the normal features u will find in every good
file-man.
S�mi
i'm using seleQ and a found out that its better.why? coz seleQ has the function tohide those files from others viewing it just like windows.you can find it under PROPERTIES
Hide the files from other viewing it?What are you talking about?!!?
BTW:You have to PAY for SeleQ while FExplorer is FREE!
You can use fexplorer, which is a program.. But you can use it to restart your phone.
Regards:
Hank Freid
