Hi there got my n-gage for christmas and i got this nasty problem.
My XP recognizes the nokia as a drive and i can move files around.If i put a .sis on however it shows that it is on the drive.
I cant install it however.My manager just doesn't recognize it.
Hope u have an answer dun wanna fone that help line
Firstly... do you disconnect your N-Gage from PC before using Manager?
Secondly...Do you copy your sis-file into root of your MMC? It cant be in any subfolder if you want to install it via manager. But if you install a file explorer (fexplorer for example), it doesnt matter where you store your sis-files. You can just browse and click with fexplorer.
ahh thanks alot i put in a dir
