Ringtones erased... possible?
5 replies · 1,932 views · Started 30 August 2002
Is it possible to delete the non-poliphonic ringtones of the phone? of course using the right software, but the question is: does it exist? does it work?
Thanks in advance
You can't delete the built-in ones because they're in ROM.
If you have downloaded any, you will be able to delete them using Recorder.
hei!!!
wait a minute
u can delete the original ring tones
using a program called SeleQ
you can download the free trial version at My-communicator.com :P
