I can not work with nokia PC suite and Nokia 6600 mobile phone.
I have a TDK Bluetooth adaptor and have installed it butt when i open PC suite i get no buttons to work with, and my m-router is not detecting my bluetooth i only get to the list a infrared detection.
Please help me i really need it to work because i work with outlook and need it for work
I had the same problem with only the infra red connection showing within mrouter.
I only solved by installing onto a different pc.
The only solution I can suggest is a reinstall of your os (which is what I was going to do).
If anyone else has any ideas....?
Try uninstalling the PC Suite and your BT software and driver, then download the latest drive for the BT adaptor (which is 1.3.2.7 I think) and after that install the PC Suite again.
I have BT & IrDA here, and both are working perfectly.
Try uninstalling PC Suite, and then the "Register Cleaner" utility + reinstall the latest PC Suite. Both from:
http://www.nokia.com/nokia/0,6771,42289,00.html
Try what say N/A if not working i give you other solution
i have the same prob n i been insta n unistalling it,i even dl the pc suite from the nokia it self....pls give me the pther solution pls...
I can't have PC Suite / mRouter see my N6600 over the infra red adaptor; mRouter momentarily sees it and immediately it disconnects. I supposed this happens because I use Win98 on the PC -- which is why nor "Modem" neither the rest of PC-side programs offred by the Nokia CD work. Yet on this forum I see that other people using the XPs experience the same problems. So what may be wrong?
