When I try to install Doom to my MMC card, it just says that the file is damaged, but if I install it to the phone, it works fine.
Is my memory card corrupted or something? Do i have to format it?
I know that Doom doesn't work on the MMC without a fix, but I can't even install the doom.sis. Other files work fine.
your download might have corrupted. i suggest you try downloading it again, and be sure to follow the installation order in the readme file 😉
I have tried to download it again, but it doesn't help. And I have a 900 game package, the same file is there too and it doesn't work either.
You need to a patch for doom in order to make it work from the MMC.
Search the forums,probably the N-Gage forum,i think i posted it there.
I got it working by formatting the MMC. I quess it was corrupted then.
