Function
6 replies · 1,459 views · Started 28 December 2003
Any idea what the difference is between the R2D02/R5AO2 organizer/CDA and R2B03/R4A02?
My P800 has R2F/R5A firmware and I'd like to know the difference with the Organizer/CDA. I read Maveric's post (Sad Upgrade) re upgrades in the Philippines and would like to know if i should consider upgrading my organiser.
Thanks.
I guess if you upgrade your firmware it will also upgrade the Organizer. Is there anyway I could removed the chinese language in my P800 because the primary language input is Chinese, I guess I bought the P802, but I doubt because system info say its is P800. Can anybody help?
Maveric
Thanks.
Organizer and CDA usually refers to your network provider (if u bought your device as contact, or upgraded it from any network provider) otherwise if it's an OEM, then it should b the simmiler to most world wide users and it should have been upgraded with the usuall firmware upgrade!
so guess there's no need to upgrade it as long as u have R2F phone, as it's the latest till now!
