Just wondering about the notes function on the 6600: is there a maximum note length and can you use predictive text to enter them?
Thanks,
Aquila
Thanks,
Aquila
Don't know if there's a maximum length. T9 works with Notes app.
Thanks, that's good to know 😊
However, something that is extremely annoying with Notes is that it doesn't synchronise with Outlook Notes. Only Calendar and Contacts can be synchronised.
Even more annoying, the Note field of Outlook appointments does not synchronise either, as there is no note field in the 6600 appointments.
I find all this extremely limiting in the use of the 6600 as a PIM.
You seem to be able to synchronise the two. I seem to have everything working, but when I synchronise it goes through the motions and then reports 0 files updated.
Any idea why the two - i.e. pc and 6600 do not synchronise? for my address book?
