P900 Themes?
4 replies · 2,455 views · Started 29 December 2003
I Just download some themes with extension *.utz. I could not install it. Do you have any idea of any software that I can use to install this. As I believe, the instal program should has *.sis instead of utz. Thank you very much for your answer. Email me at [email protected]
Copy the file onto your p900.
Then use File manager (comes the phone) to go to the file click on it to install it.
I could not move, copy, edit the file. any other alternatives?
In explorer open (my p900) then memory stick/document/unfilerd
You should be able to copy it in there.
Then run it from file manager on the p900.
This works for me!
JUST BEEM THE UTZ. TO THE P900 BY INFRARED AND THE P900 WILL DO THE REST !
WHY COMPLICATE UR LIFE ?
BUONA FORTUNA
