Original files of 3650
1 replies · 3,138 views · Started 30 December 2003
Hello,
Does anyone have the original files for 3650?
I have a 3650 from a Portuguese company TMN if anyone have it would be great. If don't i will be happy to have 3650 original files from NOKIA.
Another question: how i can re-install the software??? Somebody told me with a code like *#xxxx#* the phone will do a full reset and re-install everything. That's Truth???
Best regards,
HIT
*#7370#
make sure the battery is full or the phone is on AC.
you will need the lock code (default is 12345, if you haven't changed it).
all user-data (contacts, messages, settings, installed applications, etc.) will be gone after the operation.
