hi folks,
is there a possibility to use themes that were made for the nokia 6600 on a SX1.
if so, what has to be done?
thx
stlei
hi folks,
thx
stlei
No. The Siemens SX1 uses Series 60 version 1.2 and themes support comes with Series 60 version 2.0 that the Nokia 6600 uses.
stlei wrote:hi folks,is there a possibility to use themes that were made for the nokia 6600 on a SX1.
thx
stlei
Why have you resurrected this post? The answer, as N/A pointed out last year, is 'no'.
N/A wrote:No. The Siemens SX1 uses Series 60 version 1.2 and themes support comes with Series 60 version 2.0 that the Nokia 6600 uses.
No, the SX1 cannot be upgraded. You can install new/update firmware releases, but they will still have the same Symboan OS 6.1 and Series 60 1.2.
