hi,
last week i saw a 256 mmc from memorex. it costs 119 euro's. but my question is, will it work on the 6600?
thanks
hi,
thanks
Apparently, Nokia recommend a maximum of 128MB MMC cards, but many people have posted on here stating that they have used 256MB and had no problems at all.
At the end of the day, only you can decide. If it doesn't work, or it messes up your phone, you will have no come back.
But, the guys on here are VERY reliable and I would trust their judgement when they say it does work.
Search the forum for their recommendations as to which make of card they have used and tested.
Rob.
Some brands do work,some don't.Until you tested it,or someone else you know tested it,you can't be sure.
Try www.tecic.com.tw,the do work.
