6600 + Opera + Web Interface for Remote Administration
3 replies · 6,457 views · Started 31 December 2003
Will this work ?
I tryed to connect to my pc that runs Web Interface for Remote Administration (windows)
I can connect and login with and without SSL but when i get in i get this message :
The web interface for remote administration
is not avbilde because because of you internet explorer security settings.
To access the web site you must enable client-side scripting......
can i enable client side scripting with Opera or any other web browser for 6600 ?
or is there another way to remote administrate my pc with 6600 ?
In Opera settings, make sure JavaScript is enabled.
If it doesn't work, create a web based admin interface of you own that doesn't depend on client-side scripting.
Alternately, use something like VNC or SSH/PuTTY for Series 60.
I've never heard of this web admin tool but it probably uses VBScript rather than Javascript. Opera does not support VBScript I'm afraid,
As N/A says you could write something yourself, either using client-site javascript or server side vbscript
