UIQ 2.1 emulator - can not run programs
2 replies · 2,129 views · Started 31 December 2003
I have UIQ 2.1 emulator for Windows. I click in menu Launcher to Instal, select aplication and install it. Then I click to Unfiled and run aplication, but I see now "Not suported" and program can not run. What I do badly?
Just in case this isn't clear:
The emulator cannot run applications compiled for the actual targer device.
The emulator runs only applications compiled for the emulator.
It isn't really emulating the hardware, but simulating it. It is "emulating" the application programming interfaces and device behaviour, but doing it within Windows and executing only Windows binaries (Symbian source code compiled for the emulator).
It is a tool for developers to test their applications during development without having to use an actual device.
It is not a tool for non-developers to test finished phone applications on a PC.
So:
If you have an application compiled for the emulator, and not compiled for an actual phone, you need to be more specific about your problem.
pavelbures wrote:I have UIQ 2.1 emulator for Windows. I click in menu Launcher to Instal, select aplication and install it. Then I click to Unfiled and run aplication, but I see now "Not suported" and program can not run. What I do badly?
Hey , if you get the solution plz , forward it to me. Desparately need it.
