My New Theme
34 replies · 11,718 views · Started 31 December 2003
HI!...
AEFox here 😃
This is my new theme...
i called AEPro Theme ...
Hope you all like it as Blue Theme 😃
This is for Executive Users 😃 more PRO Look 😎
hehe! that fade effect on the clock hands rulez! 😃
this theme will be available on www.Zedge.no soon!...
cya! 😎
OK!...
here you can get the AEFoxPro Theme Pack 😃
AEFox PRO Theme
On the ZIP file you will find the SIS, the Wallpaper and
the OpLogo ...
The SIS does not contain any ICONS or Wallpaper ...
So you can use any other theme icons, like the BLUE Theme icons for example... just go to edit theme and set it up on ICONS what you want to use... and put the Color PALETTE on GREY to match some arrows that are used by default.
The wallpaper set it as always, go to gallery select and view the image, and then on Options, Set As Wallpaper...
Enjoy! 😃
cya!
The SIS file will be available soon on Zedge.no , but you will miss Oplogo 😃 .. Zedge you will need to open a section for oplogos too. And BTW! remember that 6600 wallpapers are 176 x 143, that resolution is not available on your site.
VERY nice as usual when it comes from you! But I dont understand why you didnt add transperency to the icons? (the white on the left side of the clock, and on most other images!!) Hope you post a updated version becuase almost everthing else look perfect!!
THanks
hi!..
i don't understand ...
What icons?... i don't put any icons on this theme ...
and all that could be transparent .. it is transparent..
so may be you are using icons from other theme that
are not transparent bg ... try using other icons, like default
ones or from my Blue Theme like i showed above
thanks!
cya!
ok .. i know what you thought ..
you thought that the top metal was filling the top...
but the top metal bar was not filling the left of the screen...
i did that in that way is not a fault or error ...
so you thought that the icons at the top left are not bg transparent but yes ... they are...
Well...
To EVERYBODY.. now you can DOWNLOAD AGAIN the new
version...
AEFoxPro 1.2 (Top Metal Bar Fixed)
Remember to upgrade the new attached oplogo too, and assign the GREY Palette (on edit)
Thanks for your comments..
cya!
In the second Screenshot the theme there is a icon or sign of red colour along with "atencion"... does that come only with that particular language or is it something else coz it aint there when a call is connected in my case...
Hey! the new versi�n only fix the top bar.. looks almost like you can see on the screenshots over there... Just Download and see it by your self 😃
About the red symbol... that is a Thumbnail Pic that i assign to my operator numbers on Contacts... that's why you can see there... 😊
cya!
HI!...
I fixed some things on my Blue Theme...
Now you can Download the new version
AEFox Blue v1.5
Hope you like it...
And Zedge please if you can Update this Theme on your site ?...
Thanks!
cya!
HI!...
This is my first Celebrity Theme...
The first of Britney, i am thinking to make some more of Britney because i have some good pictures that i want to use, but the best way to make a theme is using one picture at the same time only, for technical reassons.
I only will change the picture motive to make some other celebrities themes...
Hope you like this first one of the series 😃
This theme will be available at Zedge.no soon, but remember
that only here you can get the OpLogo and some tips to make
the look like you see on this screenshots...
cya!
DOWNLOAD:
AEFox Britney Theme 1
ScreenShots:
Hey! Thanks!..
here it's the last Britney theme from me 😊 ...
Now i move on with some others models motive 😃
This is Britney 2 .. now you can see 3 differents pics of her and you can use the Analog Clock.
You will find some Tips attached to ZIP file to get better look..
hope you all like it! 😃
this themes will be available at Zedge.no soon... but the oplogo and tips you can get it here only by now..
cya!
Download:
AEFox Britney 2
Screenshots:
great job on the aefox pro theme..but there is one problem about it, when u go to register, the time/date doesn't appear because it's written in white..
Hey! Sick_7650 ...
I don't know what you talking about?...
What field?.. what register?.. date time?.. when you turn on
the phone by the first time?...
Do that with other theme first and then you never will do that date/time register again so i don't know what is the problem if that it is.. i am not sure...
please tell me where it is...
thanks!
cya!
HI!..
This theme is my last theme, about a day ( 14 hours) working on it ...
Hope you all like it...
you can use any icons you want...
Put grey palette...
You will see some little pixel out of place at the edge on the status bar, that problem is from Theme Studio, i was hours trying to fix that but i couldn't, you see it fine at the preview, but look like this at the final result, sorry about that 😞 , let's see if this will be fixed at some future version of Theme Studio.
cya!
Download:
AEFox Fusion
ScreenShots:
hi
I love your blue theme but I would like to ask you if you could do some cosmetic changes on it ?
First of all it is very difficult to read the clock accuratly with the blue bubble which is a bit too dark. Could you enlighten it so that we will see the watch behind ??
Then would it be possible to remove the nokia image in the menus and just leave the blue background ?
And finally could you post the same theme with these modifications and without the themed icons but with the nokia original ones for the applications.
As a mac user, windows icons are not that beautiful
i know that this is a lot but as it is sunday ..... 😊 😊
you can send the modified theme at [email][email protected][/email] if you wish....
And thanks in advance
hi!..
i can do all that changes on the next version...
but... the icons thing that you ask
sorry but is a newbie question 😉 ...
You can assign any icon pack to any theme... you know?...
go to the theme EDIT and go to ICONS and put the default or any other icon pack from other themes... more easy by now too you do that don't you think? 😃
That is the kind of questions of the MAC users lol! 😉 they never use the OPTIONS (if they have it) always want things ready to use lol! ... sorry but MACs are toys and i hate them .. hehe! cya! 😃 but i respect you that selection.
cya!
@aefox: its in the log menu...when u go to see all logs, the date/time for a certain call/sms doesn't show because it is in white, and so is the background..i'm talking about aefox pro theme...great job on the new theme btw 😉
hey! Sick!..
sorry but i see it 😕 ... i see all the LOGs.. because
that date time and the name of the contact is in BLACK TEXT not white...
So.. i don't understand why you see in white 😕
first time that someone tell me that ...
i really don't know why your device don't set it up that text like the others or mine too...
sorry! 😞
cya!
ok got it Sick...
But i can't do anything about that...
Because i don't set ip up any text in white color...
So i think that Theme Studio don't have the colour option to change that text... and curiously is the only app where are white text in that area, that's why i don't see it.
sorry!
cya!
Foxy - this theme is better than your slauncher ones!
Good job!
You could sell these mate 😊
Take a look at www.openbit.com - they have a technology to encode your files and it'll charge the user �1.50 via sms to use your product.
Open Bit License Manager Technology� is product portfolio consisting of two client-server solutions (Standard Edition and Pro ) for enabling efficient and secure 3rd party application distribution. License Manager Technology contains application super distribution, copy protection, micro payment (billing) and License code management architectures. License Manager is thus ideal for all Symbian platform mobile application and content developers.
Of course WE would still get them for free 😉
Cheers
Will
Mmmm.... as for the newbie I agree, forgot to play with all the options !!!
As for the macs, sorry to disappoint you but all windows are just way to old to compete with OSX and Unix core.
And you're right, you just work with a mac while you play with options and files in wintel !! 😃
Anyway, thanks for the modifications that you could make.
One last suggestion on your last themes, it is not very easy to see the level of battery and reception with your new icons, could you just make white bars instead of grey ones ? or just use the standard ones as in your Britney themes
