help!!
4 replies · 1,202 views · Started 31 December 2003
hey wish u all happy new year..
in my fone, when i try to send an mms, the 'G' icon blinks and then when it stops blinking, its stays idle and goes back to the aerial sign.. help.. pls ppl i reformatted my fone, but not mmc, copied all my messages to mmc. and then reformatted it. (mmc not formatted, all important data in it). tell me wat to do.. tks in advance
Try changing your GPRS connection settings to "only when needed" which can be found in Tools>Settings>Connection
This should help, best of luck
Nooo...it's already kept like that.i don't use use always online.plzz..shud i hve to take my fone to a nokia care shop or somthing like it..it's like am mmsless on new years day...😞 😞 😕
Sounds like GPRS is not avalible in your cell.
Do you have another GPRS phone you can see if there is any service, also try switching your phone off and remove battery and sim for 20 mins.
Give your network a call too.
I had a simular problem once, I called my network and although they said there was no problem their end, It was working 10 mins after 😉
Will
hey..that did'nt work..so i gave my 3650 to nokia care for it to be re-flashed 😞 i've spent rs.1000 ($20) for it..i hope they repair it..i really love that phone.that was the first problem i ever faced since i bought it in february 2002.such an amazing phone that was.😊 i'll keep u updated on what happens.bye!
