when i run mp3go on my 6600, nothing seems to happen. i completed the install properly and run it as instructed, but the screen just changes to blank for a few seconds, then returns to the menu.
anyone managed to get it running successfully? do i need to have a headset plugged in?
tia.
don't know if this software works on the 6600
but i can tell you that ultraMP3 works very well on the 6600!
RealPlayer Advanced plays MP3s and from what ive heared the quality is supposed to be pretty good.
can anyone send me ultramp3 software with full register plss...!!!
No. Buy it.
Consider this an official warning.
i have loads of mp3 on disk how do i get them to the phone thanks .
Why do you need an Mp3 player,when pc suite converts them into .wav and plays them that way??
The quality is the same.
You can cut bits out using a wav editor and then use them for ringtones,text etc.
Is there a reason for having mp3 coz i cant see it??????
What U mean by RealPlayer Advanced? Can this one run in N6600? Where can I get it.?
how to use pc suite , by the way i hav try before using wav editor but the space seem very high. a 25 sec actually took about 10.2 mb .can anyone teach me how to cut it better or maybe some software can compress it.......
exactly the quality is the same except mp3 is the most popular compression method for wavs (cd audio) adn can sometimes reduce the file size by ten time your average song is usually between 3.5 to 5 mb a total waste of space to use wavs
so..
from pc suite transfer mp3 to phone is converted to wave then how about the space needed . is it the same as mp3 or converted size of mb .
your telling me pc suite converts mp3's to wav ?? disable this or use other software if u are wanting to listen to music and use the wavs for ringtones i think thats how it works there will be a way to transefer thje mp3 file to your phone and use mp3 player software to listen to it
