Troubles with mobiplayer
2 replies · 2,023 views · Started 01 January 2004
I was using mobiplayer and virtualdub.But after i changed my MMC card for bigger,nothing is working.I installed Mobiplayer again on the card,it's not working.I tried to install it in a phone memory,the same result.Mobiplayer is fine,it was working before,but it just doesn't see the movies.When i try to run them from FExplorer there is "!!Unknown file format".And the movies are fine because i checked them on the mobi emulator on my pc.Where the mobiplayer should be installed?And where do You place mobimovies?
I have had this happen to me once or twice. Basicaly the way i remedied it was placed the files in the root directory(if z is the drive leter of your mmc then z:\mobilclip.mo). Then use fexplorer to look at it. when you click on it if it says uknown file format just turn your phone off and on again and your file should now be recognised as a bonified mobilclip file and the little sunglasses icon should appear next to it in fexplorer. All you have to do now is click it and it should play. Good luck
