BT head sets?
4 replies · 2,901 views · Started 02 January 2004
hi
iwas wondering if it is true that with bt headset you can only talk and recieve phone calls and it cant be used to hear mp3s , radio, or game sfx?
is this true???
thanks
not true - I use my Jabra BT200 to listen to music on the way to work every day.
TIP: encode the music in one big .rm file @ 56kbps
sounds just fine and dandy 😊
The only thing you can not use it for is radio, as you need a wired headset as the wire acts as an arial.
Thou never tried plugging in wired headset and BT at same time and then listen to radio?? Could work??
Will
Games are OK, too. What won't work is FM radio receiver, if the phone is one that needs a headset with wires to be connected as the radio aerial/antenna.
Do you know if what Will suggested would work? Connect a wired headset to act as the FM aerial, then listen using Bluetooth?
