A few questions about my new orange 6600
2 replies · 1,400 views · Started 02 January 2004
Hi
Firstly is there anyway of sending all my contacts from my 7650 to my 6600. can you use the PC Suite?
How do i sort call waiting and call divert out. Can seem to see the menu option like on the 7650.
Am i able to surf the web using GPRS. Do i need some sort of web browser program?
thanks
On the 7650 there is no send all option😞 Call divert is not supported on orange any more and if you want to surf the net then you will have to download opera browser. hope that helps.
Run the 6600 PC Suite and then go to Data Import. You can import contacts and calender items from the 7650.
