Hi, I am using the newest Opera Version 6.20. It won't connect to the Intenet. When I am Using the Built In SE Webbrowser, I can use the Internet fine, no problem. but it will not work on opera, even if I establish an GPRS Connection with the Built in Browser, Browse to the internet, an then start opera and try to open a web page. Anyone know this prob? Thanks, Judy.
Opera Problem
Do you know if the GPRS account you have set up is a WAP account or a standard internet account? If it is only WAP enabled, then this may cause your problem. Give your service provider a ring and find out. They may need to activate something on your account.
I really don't know exactly. But on my p800 it worked fine without setting anyting up.
I found the answer on http://www.esato.com/board/viewtopic.php?topic=46459&forum=35
as well as
http://www.opera.com/support/search/supsearch.dml?index=689
Works now for me!
