left right selection keys
2 replies · 1,547 views · Started 02 January 2004
is there a way to rename these? i waant to rename mine that says t-zones to another name because its the only shortcut to services that hhas auto connect so please help!!!!!!!
Yes, og int o the applications screen and find the SETTINGS icon. Select this, and choose DEVICE and STAND BY MODE. You can select the two applications to show on the soft keys from this dialog.
