How would i get themes that you have made onto my phone? what file extension has it got to be. cheers chaps
How to put themes on a 6600
I had the same problem then I downloaded just the .SIS themes and they work smoothly.
Just send the SIS file to your mobile (I used BT) and install the "application".
In the "Theme" menu just remember to select the right memory... 😉
Ciao,
Andrea "Rigido".
how would i go about sending them to my mobile, i just got it. some of the themes are excellent and i would love them on my phone.
Well, you just have to use an IrDA connection or a BlueTooth one.
There are a lot of adapters (I use an USB -> BT adapter).
Then you can use any "file manager" to send the .SIS theme to the mobile. The phone will ring as it received a SMS...then you have just to read (Install the application).
Ciao,
Rigido.
