Weird GPRS problem
2 replies · 1,613 views · Started 02 January 2004
Hello,
Just wondering if I'm the only one who has some problems or not. When I connect to ICQ using IM+, after a while, the operator logo disappears. And I get a '\' on the 'G' (GPRS isn't available). And sometimes the signal disappears too!
I've a very bad luck with phones!! Every mobile I got had a problem, the same is happenning now with the 6600! 😡
that problem is not the phone..
is the software and the service that are provided by them..
IM+ and AgileMessenger don't work always...
Servers are down or something like that..
Don't worry about the phone...
cya!
Thanks for the reply, are you telling me that you have the same problem? Disappearing things!
It sometimes happens when I use GPRS (sending MMS or using nICQ) 😕
