so what everyone is saying is that i need to go and get a nokia-ngage memory card, and that the reason i cant detect a removable drive on my computer with the USB is because i cant put information directly onto my phones memory card or my sim card memory? so to solve my problems i go buy a memory card (the n-gage type) and put that in my n-gage, hook up my computer with the USB and go to My computer-removeable drives. and this way i can put stuff onto my phone, i wont get the message "please insert disk into drive F:" or whatever?
ok i think i get it
Well yea basicaly
You need an MMC card not SD be carefull when you go into shops they will quite often show you SD cards aswell thinking they are doing you a favor. So use an MMC. Good luck
hi, here's a little friendly advice just in case you may not know.....you don't need to get an mmc made especially for the n-gage (ie nokia brand). almost all brands of mmc cards will work with the ngage. the only reason i'm telling you this is because i've noticed the mmc cards made by nokia are twice as much as your average mmc....however, they're just the same thing. but just as shadow12 says, just make sure it is an mmc and not sd card.
