as we know,there are two answering machine softwares for Series 60,which can be used on 3650,
the Answering.Machine v1.20 and the SmartAnswer 1.06 .
who can tell me that which one is better in both features and DIY.
and ehich one is more popular?
Thanks.
Which is better?THX...
Iv tried SAnswer software for nokia 3650 and its doing pretty good so didnt think of trying the other software...SAnswer is pretty handy and good so im sticking 2 it 😊
I bought the 1.20 version, but I am not satisfied. It seems the best choice among its competitors, but it has stability issues.
Most of the times I use it it crashes at the end of the call and looses the recording. I saw others having the same problem, but it does not seem to affect any 6600. Other times it answer the call but the message does not start...
After a first kind answer from their support - asking me to verify that I was specifically using the 6600 release - I had no other feedback from them. It is not fair.
Giacecco
