AgileMessenger problems with MSN
25 replies · 5,282 views · Started 03 January 2004
Hi all,
while I was able to login to MSN using AgileMessenger (I downloaded the latest bit from their homepage) I can see all my buddies but all of them appear offline while I doublechecked on my laptop that when I login on MSN that some of them are actually online. I was wondering if anyone else was facing the same issue?
Best regards,
6600fan
If you just checked a topic called 'Agile Messenger' in this page, you would find the answer to your question right away.
Take a look here.
Some ppl have the same problem here, Agile Messenger doesn't connect at all on my 6600.
yep..
to me don't work ..
not connection at all...
stay on : Establishing connection with Master Server... "...
Forever...
cya!
Originally posted by AEFOX
yep..
to me don't work ..
Same problem here too..!!
ok now that we know that there are problems with this application on nokia 6600 does anyone know if there is going to be a new realease or a fix for this product avaiable soon?
Did anyone contact the guys that wrote agilemessenger for this question?
Agile Messenger was working just fine for some time ago...
then ... at some momment stop working..
i think that Agile has some problems with their servers,
because at some places is working and others don't...
i hope that Agile co. fix this problem soon... 🙄
cya!
yep..
to me don't work ..
Forever...
cya!
Same here 😞
hi!..
try to use TipicME...
At www.tipic.com it's freeware too..
cya!
I tried that last night, but I can never get connection to MSN server.
Use the PC version of Tipic app to setup the Transponder to MSN account...
Then you will see on the phone version too...
cya!
cya!
So I need to download the PC version and do the setup from my PC? Then I can use MSN via my phone?
Today I tried to connect using Agile Messenger, I got a msg says: "New version is available, do you want to update" I downloaded and installed the new version, but it doesn't open at all 😕
Can anyone try it please?
Thanks!
I downloaded the same upgrade after it prompted me on my phone. Mine won't open too! The upgraded version is not available on their web site either!
Simon.
v2.00 dont seem towork 😞
v1.31 works fine on my 6600 you will need a FULL gprs port to connect a lot of networkks limit the conenction to Web Traffic only which could explain why some users cant get connected
EXCELLENT! .. version 2.0 for 6600 of Agile Messenger Working! 😃 ...
Work perfect by my GPRS IAP ... connecting to MSN
And i notice that now we can choose a different IAP, like the mRouter by BT but not work for me... don't know if is not active yet...
cya!
I'm happy now!! Finally I can connect to MSN on my phone!! And it looks great!
What is cya ?
See ya maybe? 😛
was sittin in front of my pc and installed the agile messenger that was posted in this thread
logs me in now (and signed me out on pc) which it didnt do before
but all my contacts are offline?
any ideas?
any ideas?
I guess they don't want to talk to you 😃 😃
