Ir Remote Psiloc............
13 replies · 5,031 views · Started 03 January 2004
Does anyone know why it doesnt control my sky satelite????????
On either setting 1/2..Really cool otherwise....
Is sky on the list of supported manufacturers? - If so, there are different manufacturers of the Sky box aren't there, e.g. Pace. maybe yours is not supported also.
Elton what range can you get using that program to your tv roughly?
All is says is Sky Digital 1 or Sky Digital 2,my digibox is Amstrad and that make isnt on the list at all,Psiloc do do another version of the Ir which can be "Taught" the codes but it seems like a bit of a mission and im not too bothered as it works all my other equipment..The range is approx 6ft.😃
.......I have also tried it on afew other sky systems with no joy either Adam.
But still a good laugh being able to go round mates houses and pubs and being able to use volume etc on there tellys.
im still awaiting delivery of my 6600, when i saw that remote app thats what I thought.. but not much joy with only 6ft for the pub etc really!
I have now tried it out on more equipment and it seems the range depends on the quality of what it is controlling.....
On my mates Pioneer amp the range is appox 20ft which is obviously much better!!!
i cant register my product... it says go to about, then enter code? i get an error message! any suggestions? what version is the one where you can "teach" it and where can i get it from?
Has the trial period expired then?
Did it work during trial?
The other version is on the site too as "full remote" you can download additional equipement codes to pc then transfer them to the phone.....🙄
The remote just closes when i go to about!!! and no, the trial hasnt expired...
What is the website called were i can download them from!
anyone encountered any devices that they cant control ?
for about 17 or 18 british pounds the total iremote looks great think i will be purchaseing it any any complaints or gripes about it ?
It should work without register,but you only get about 30 button presses b4 it shuts down.
Only sky doesnt work so far mate.
cool well i dont have sky ive got the telewest broadband digitial its a pace box i noticed some pace digibox machines on the ccf site which has all the codes for remotes hopefully mines is on there 😊
