Fullscreen Videos with 24 FPS !
8 replies · 4,646 views · Started 04 January 2004
At http://www.mobiclip.com/ you can download a free copy of the mobiclip-player (56 kb SIS-File) and file encoder that converts .swf, .avi, .mov, .mpeg and .mp3 to .mo files.
Videos and animations can be displayed in fullscreen-mode (176*208) at 24 FPS.I made some test videos (yeah some adult stuff *G*) and the were shown very smooth and in a superior quality compared to realplayer and pv-player.
If you want to keep the files smaller you should chose framerates between 12 and 15 FPS.
If you try this program, you will forget about the other players.. i tell you 😉
this could be the new standard for movies on our phones!
greetings
LQ
WOW the Quality is really amazing.I made som videos from avi files and they were very good.Can someone tell me how to open a SVCD in virtualdub?I would lake to convert some movies .
Thaks Tim
Excellent quality but MASSIVE files.
and audio is a little quiet - encoding is a 2 stage fiddly process.
I prefer Philips camcorder for standard .3gp playback and in full screen too! 😊
And for streaming it simply has to be Oplayo 😊
Will
I have no problems with audio.. just press the left menu button to select the volume-control 😉
Hi i have problem seriously for convert type of flash .swf at .mo
Not exist for audio with sometimes error:
Invalid Audio Format (should be RAW 44100 Hz 16 bits mono)
Is fix for problem?
To encode from svcd to .avi in virtualdub you need the older version of virtualdub . i think its 1.4.10 or older. It will support mpeg. The newer versions won't. You can also find it on the web as virtualdubmpeg.
www.doom9.org or www.virtualdub.com might have the older version..... good luck
ASF is Microsoft's propriatery format.There are just a few applications that can manipualte ASF files.Find one,convert the ASF to AVI and then to RM.
