can seem to make either MSI dongle 1.3.2 to work!!!
PC Suite cant detect phone!
tried to update software to 1.4.2.8 from www.msi.com.tw, require BD Address, i keyed in mine, they said wrong format.
wrote in, waiting for reply now.
anyone using MSI BToes PC2PC dongle?
can share ur setup?
thanks!!!
I have MSI dongle here, driver 1.3.2.7 and it works like a charm.
To start with, you have to pair them, then in the mRouter check all Bluetooth COMs, after that right click on the BT icon in the taskbar and go to Quick connect, Bluetooth Serial Port, and then choose to connect to your phone. The connection will fail, but the phone will re-connect by itself.
That's what is happening here, hope it helped.
i agreed that it worked... cos it worked for 1 week exactly wat you mentioned...
then i dun understand what happened... it didn't work anymore!
now instead of the "com0" msg, it mentioned "cannot connect to remote device"!
i am so tired after figuring more than 8 hours yesterday....
installing and uninstalling software, drivers, etc....
anyone pls help?
thanks
connected again to pc suite today...
after i off and on the phone...
weird...
thanks to the advice from fellow forumers...
thanks!!!
