Video Recording Issue on P900 !
9 replies · 3,471 views · Started 04 January 2004
Hi all, I am using the P900's stock video recording function and try to record a 15min clip, BUT the phone will not save anything that is over 5mins (i tried 1hr or 30mins or 15 mins or even 10mins ...) of video that I recorded (even though it says i can record up to 90mins on my 128MB [white color] MSDUO or 25min on the phone's internal memory. It doesnt say that it cant save, but the BUSY word keeps on flashing and flashing. I guess its trying to save (processing?), but I let it sit and process for over 1hr or even 1.5 hrs to save a 15min clip ....... and it just keeps saying BUSY .....
Is anyone able to record anything more than 20mins and able to save it to the phone's internal memory or the memory stick?
I am sure I have enough hd space (internal or external) to save my 15min clip .... even the counter up top says I have lots of time left ...... but it wont save ....
Anyone encountering this problem ?
I am currently running version
Organiser:
CXC162021 R1A05
CDA:
CDA162004/14 R2A01
Please help, thanks =D
Hmm, thats weird.. I havent had any problems recording 5 minute video except that one time whilie i was doing it, the phone hanged and I lost the video was recording, but that was just one time.
A bug that I notice though is that after you record a video, make sure not to close your flip right away bec it ends up not being able to save the video you took.. you have to wait a few seconds for it to save..
Yeah I let the flip stay open .... but I let it sit there and do its own thing .... and I waited over 1hr for it to save a 15min clip ...... and still doesnt work .....
the word BUSY keeps on flashing up top .....
so hmm whats the longest clip that you have recorded ? and quality u used ?
I think around 8 mins.. but ill try to test it again later and ill check the quality too! 😊 Will update you after
Cool bud , thx ....
if yours is 8min ... hmm can u try to record one that is 10mins or even 15mins ?
coz well I tried using High quality video/audio and Low quality video/audio .... but both resulted the same ....
Finally I had time to test it last night and used up 11mb of space to record around 12 minutes of video, no problems here 😊
My suggestion is, do not close the flip right away after taking the video because this will cause the built in video app to hang..
I also recall before, I was recording at our christmas party and suddenly it hanged at around 7 mins, but this has never happend again.
My recommendation is:
1.) Update your phone to the latest software.
2.) Reformate your MS DUO 😊
thx for testing for me .... but hmm yeah I didnt close the flip and i already flashed the phone and reformated ...
damn .. they need to release a new version of firmware for me .. i am still on R1A05 (CDA) 162004/14
