Series 60 Emulation for PC?
3 replies · 2,779 views · Started 04 January 2004
As the title says, is there a Series 60/Symbian emulator for PC?
I have seen the one on the Nokia site for developers, but its over 100mb to download (im on dial-up)
I just need to test a few applications, because my Nokia 6600 is in for repairs.
thanks.
The one for developer can't run applications compiled for the AMR platform so its not of any use to you,unless you write your own applications or have the sources of the applications you want to try.
Search for GameMagic,it can run Series 60 MIDlets on PC.
Searched for GameMagic and it works great ! but the downside is you can only test java games and it doesn't support symbian installation files (SIS)
anyone have a program for this?
As mentioned, there isn't one. The SDK is more of a "simulator" so as GhostDog said, you need to compile the Symbian app sources for the emulator/simulator, but you cannot run actual binaries intended for a real phone.
