Adding ring tones to Nokia 6600
2 replies · 2,345 views · Started 04 January 2004
Just got my Nokia 6600 yesterday. I want to add new ring tones to the phone. I tried copying the file over to the Memory device using the software provided by nokia but every time i try to transfer a midi file it crashesh. I can trasfer images & stuff but no audio files.. Can anyone suggest a solution or any other software that might help ?
Smartdevil
hey smartdevil,
what format are u trying to transfer? is it midi or wav or mp3 format?
if midi and wav, just transfer it without opening pc suite
if mp3, did u install the converter while installing the pc suite?
or just convert the mp3 to wav using itunes or other programs then decode it using mp3 to wav decoder programs
Hi daniatt
I was trying to transfer a midi file... but will try transfering it directly now.. Thanks for the reply 😊
