Image files
8 replies · 2,275 views · Started 04 January 2004
I was just wondering if i could get a animated GIF file as my background?
please help me if you know what i am on about
cerberlus wrote:I was just wondering if i could get a animated GIF file as my background?
yeah you can put animated gif on your phone, but it wont run continously for some reason.
�tudz wrote:yeah you can put animated gif on your phone, but it wont run continously for some reason.
You could use Psilocs ScreenSaver or Powerlock. But only as screen savers not wallpaper. :frown:
Kamalayan wrote:You could use Psilocs ScreenSaver or Powerlock. But only as screen savers not wallpaper. :frown:
PSIOLIC SCREEN SAVER IS REALLY A NICE APPLICATION.
Psiloc Screen Saver is very good application but will drain your battery.
i am using skreen saver and its also quiet nice but u can place .gif in that.
Vicky wrote:Psiloc Screen Saver is very good application but will drain your battery.
Psilocs Screen Saver can also use animated GIFs as Screen saver and if skreen saver can do that as well, does that mean skreen saver can optimize the use of your battery better compared to Psilocs Screen Saver? (thats a bit out of context comparison.)
wallpaper changer and I think smartprofiles 2 can change your background into an animation ...
As standard the current S60 handsets store the wallpaper in an *.mbm file, this contains a number of bitmaps, this inturn cannot hold an animated image. You can however set an animated *.gif as a background and only use the first frame of the animation.
So it looks as everyone above has said, only via 3rd party software.
Anyone try'd setting a animated *.gif as a start-up image?
That would really be nice sir. Like windows xps boot up screen. 😃
